How To Resolve The 0x80070002 Printer Error?
Hello, experts. I am getting the 0x80070002 printer error while trying to print something. Please help me to resolve the error. Thank you.
Hello. Getting the configuration problem with the printer. Printer displaying 0x80070002 printer error code while trying to print something. Follow the below points to resolve the error.
• Remove the printer’s cable from the system.
• Go to start, click on it, then go to settings -> devices-> printers and scanners.
• Search for your printer name under the list of printers available, click on it and remove the device.
• In the windows, search type, print management and click on the result.
• Click on all printers, locate your printer right-click on it, and click on delete device.
• Restart your PC.
• Now, reconnect your printer cable, download & install the software and driver.
• Now it is all set and ready for use.
Notifications
