How To Resolve The 0x80070002 Windows 10 1903 Error?
Hello, people. I am getting the 0x80070002 Windows 10 1903 error while trying to update Windows 10 version on my PC. Please help me out to resolve it. Thank you.
Hello. Getting the 0x80070002 Windows 10 1903 error while trying to update Windows 10 version. Follow the below-mentioned steps to fix it.
Method 1:
If there are any third-party antivirus software on your PC, then uninstall them.
Method 2:
Reset Windows Update Components.
• In the Windows, search type command prompt and click on it and open it as an administrator.
• Next, write the following command prompts.
• Note: Hit enter after each command.
“net stop wuauserv.”
“net stop cryptic.”
“net stop bits.”
“net stop msiserver.”
“Ren C:\Windows\SoftwareDistribution.” “SoftwareDistribution.old.”
“Ren C:\Windows\System32\catroot2 Catroot2.old.”
“net start wuauserv.”
“net start cryptic.”
“net start bits.”
“net start msiserver.”
• After completion of running the above commands, restart your PC.
