How To Resolve The 0x800700b Windows 10 Error?
Hello, experts. I am trying to activate my Windows 10, but it fails and displays 0x800700b Windows 10 error. I have tried many methods, but it shows the same still. Help me out. Thank you.
Hello, learners. The 0x800700b Windows 10 error occurs because of the corrupt entry in the system log file. It is simple to solve this error, follow the below methods.
Method 1:
Reset the file system log.
• Go to the windows search box, type command prompt, right-click on it and open the command prompt as an administrator.
• Enter this “fsutil resource setautoreset true C:/” command and hit the enter button.
• Next, reboot your PC.
• Then try installing or activating Windows 10 on your PC.
Method 2:
• In the Windows search box, type cmd, right-click on it, run the command prompt as an administrator.
• Type the following command and hit enter.
“slmgr.vbs –ipk YYYYY- YYYYY – YYYYY – YYYYY – YYYYY.”
Replace the ‘y’ alphabet, with the system product key.
• In the next line, enter the following command and hit enter.
“slmgr.vbs –ato”
• Reboot your system and try activating Windows 10.
