How To Resolve The 0x8007016a Error?
Hello. I was trying to move files from one drive to my device storage on my PC, and I am getting the 0x8007016a error while doing it. Please help me with the solution. Thank you.
Hello. The error 0x8007016a is known for the file not responding or error while removing a file. To fix this error follow the below methods.
Method 1:
Reset OneDrive.
• Hold Windows key + R, enter re-edit in the dialogue box, click on ok.
• Next, enter the following command in the Run dialog box.
“%localappdata%MicrosoftOneDriveonedrive.exe/reset”
• Next, click on ok.
Method 2:
Deactivate files.
• In the windows search type task manager and launch it.
• Search for OneDrive and right-click on it.
• Click on more options.
• In the next window, click on settings.
• Navigate to files on-demand option and uncheck the box beside it.
• Next, perform the reboot.
