How To Resolve The 0x8007025d Error?
Hello, people. I was trying to install the updates on my PC, but it is displaying the error 0x8007025d. Please provide a solution to resolve the error. Thank you.
Hello. The error 0x8007025d will display when bad HDD space or sometimes because of corrupt ram. Follow the below solutions to resolve it.
Method:
Reduce the size of the drive.
• To install Windows you just need a size of 20-30gb space. So, create a disk partition of 125gb size to resolve the error.
• To create disk partition while you are installing Windows on your PC. In Windows installation media, select custom: Windows only(advanced) option.
• Delete all the old partitions and create new partitions. Remember, one should be around 125gb and remaining of your choice.
• Next, select the 125gb size partition to install the Windows
