How To Resolve The 0x80072ee6 Windows 10 Error?
Hello. I am getting the 0x80072ee6 Windows 10 while trying to update and install new versions on my PC. Please help me out with the method to fix the error. Thank you.
Hello. The 0x80072ee6 Windows 10 occurs when the updates are not installed because the service has been stopped. So, to fix the error follow the below methods.
Technique 1: Run Windows update troubleshooter.
Technique 2: Restart BITS
• Hold Windows key + R; it opens a run dialog box.
• Next, type “services.MSC” and hit ok.
• In the opened window, search for Background Intelligence Transfer Services, double click on it, select its properties.
• Set Automatic(delayed) as your startup type and click on apply.
• Click on start and stop to stop and restart the BITS services.
• Click on Ok.
