How To Resolve The 0x80072efd Error?
Hello. Whenever I try to access the Windows store on my PC, it is showing the 0x80072efd error. Please suggest a method to resolve the error. Thank you.
Hello, learners. The 0x80072efd error keeps on shows that check your connection, even though your internet connection is good. It is quite an ordinary error, and we have suggested some possible ways to get rid of it. Please follow them.
Method 1:
Update Driver’s.
• Go to the browser and download & install the ”driver easy” application.
• Next, open the application, click on scan now.
• Next, click on update all; it will automatically download and install all the required drivers.
Method 2:
Update Windows version.
• Hold Windows + I key; it will open settings.
• Navigate to Update & Security.
• Next, click on check for updates, then click on install.
• After installing the update, the error should be gone.
Method 3:
Windows troubleshooter.
Method 4:
Rename software distribution folder.
• Double click on C: drive.
• Navigate to the software distribution folder.
• Right-click on it and rename it to some other name as you like.
• Save the changes, close all the tabs, and restart your PC.
