How To Resolve The Error 0x8004005?
Hello experts, I was checking for updates on my PC, then this error 0x8004005 was displayed. Please help me with the methods to fix this error. Thank you.
Hello, worried about fixing the error 0x8004005, don’t worry, it is very easy to repair. The reason for the error is damaged link library files from your system. Follow the steps to fix the error.
Method 1:
Resolving the error manually.
• Step 1: Log on to the PC as an administrator.
• Step 2: Click on the start button, then go to all programs -> accessories, then click on the system tools and then click on the system restore.
• Step 3: Click on the most recent systems restore point from on this list, click on the restore point list, and next click on continue.
• Step 4: In the confirmation window, click on Next.
• Step 5: After completion of the restoration, restart your PC.
If this method doesn’t work, then go for the next technique.
Method 2:
Using the command prompt.
• Step 1: Open command prompt.
• Step 2: Run it as an administrator.
• Step 3: Now, in the command prompt, enter the below commands and hit enter after each one.
• Click on Ok, and restart your PC.
