How To Resolve Webex Error 5
Having used Cisco software products for a long time professionally, I decided to use some of them for personal use. I installed the required software on my home computer and it started throwing webex error 5. Is the issue solvable or do I need to call support?
Answered By 0 points N/A #321722
When using a number of Cisco software products, one can get webex error 5 anytime during the startup or closing of the software or even during Windows startup and shutdown.
The exact cause of this error cannot be determined without a system diagnosis. This error commonly occurs due to a corrupt or incomplete download. It seems that you have somehow completed a corrupted installation or the installation was incomplete. The easiest fix would be to download and reinstall a clean version of the software you are using.
