I transferred a mobile video from my mobile to my system, but it seems that the video is recorded in the landscape and now the video is playing in the landscape. Is there any way to rotate videos in VLC while videos play?
That should be no problem if you simply want to rotate the video. If you are using VLC media player, it is very easy to rotate the image. First, download the latest VLC media player and install it to upgrade your existing version. Once installed, start VLC then load the video. When the video starts, click “Pause” to hold the playback.
Next, click on the “Extended Settings” button or press CTRL + E to bring up the “Adjustments and Effects” dialog.
On the next screen, select “Video Effects” tab and then the “Geometry” tab. Check “Transform” and then select the appropriate rotation from the dropdown list.
When the image is now correct, click “Close” and that’s it.
1....
