I have lots of old disks. I want to scan the CDs to check which still works. Please provide me a method to scan the disk for errors. I am currently using in Windows 8.
If you have old discs and you want to check them if they are still readable, you can use the CHKDSK utility, the built-in drive utility in Microsoft Windows. You can use it either on the command prompt or from the Windows Explorer. To try this, insert your disc on your optical drive. When it is loaded, start Windows Explorer then right-click your optical drive and select “Properties.”
On the next screen, select “Tools” tab and click “Check Now” under “Error-checking” section. Click “Start” to begin the scan. Since you are checking a CD or DVD disc, you don’t need to check any of the boxes on the dialog.
Check the disc with CHKDSK
Another tool you can use to check your discs is PC Tools Performance Toolkit. Follow the instructions to download and unpack.
RICH Miner officially launches a new mobile cloud mining application, subverting the traditional mining model! No need to buy mining machines, no technical experience required, just a mobile phone, global users can start the...
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
