How To See A Bunch Of Videos Back To Back On YouTube
I want to see a bunch of videos back to back on YouTube. The problem is I have to select every time once a video is over. Is there any way I can solve it? If yes, then what are the steps?
The solution to your problem is making a playlist. YouTube creates automatic playlists, but it also provides us with the feature of creating customized playlists. Here are the steps:
1) Open YouTube.
2) Type in whichever video you want to add in the playlist.
3) Go to the video thumbnail.
4) Click on the “+” mark in the bottom right corner of the thumbnail.
5) Select the playlist to which you want to add this video or create a new one.
6) After adding all such videos, go to your homepage.
7) Click on the playlist you want.
Now, you can be doing your work without being bothered about what to play next!
