How To Set A Password In A Folder
I am using Windows 7 and I was wondering if it was possible to set the password to a folder on my computer. Can this be done? If so, how do I do it? How to set a password in a folder on Windows 7?
Yes. It is totally possible to set a password to any folder on all versions of Windows. It is quite easy to set a password to any folder on Windows. It is a simple three-step process.
First, you need to right-click on the folder that you want to assign a password to and then go to properties. Find the general tab. Under the General tab, you will find an advanced options button. After that, click on encrypt and then click on okay. I recommend you that before you encrypt any folder, you make an un-encrypted backup just in case you forget the password.
