How To Share Files Between Two Laptops?
I have two laptops, can I directly share files between them? How can the files be shared between the two systems?
File sharing can be achieved in many ways. Some are –
1. You can use a pen drive. Plug in the pen drive into one system and load the data which you want to transfer then plug the pen drive into the other system and copy it.
2. Data transfer can also be achieved by using cloud storage. Uploading the data on cloud storage and then downloading it on the other system. You can use options like Dropbox or Google Drive.
3. You can always use another storage device like a memory card or external hard disk depending on the size of the file.
4. For the wireless option, you can use Wi-Fi transfer software like Shareit or team viewer.
5. You can also get both the system on the same LAN network and share the data there.
Notifications
