How To Solve 0x80010135 Error While Extracting A File In Windows 10?
Posted on - 09/15/2020
To solve 0x80010135 error while extracting a file in Windows 10, follow these methods.
Method 1- Rename the file.
a. Right-click on the file.
b. Click on Rename.
c. Rename your file as a.zip (use a single alphabet, not necessarily a).
d. Extract your file.
Method 2- Download 7-zip.
a. Go here
b. Download the software (.exe) for your Windows (64-bit or 32-bit).
c. Run the .exe file.
d. Extract your file using 7-Zip.
