How To Solve 0x800700aa Bluetooth Error In Windows 7?
I am unable to connect my headsets to my Windows 7 laptop using Bluetooth. When I am trying to connect, I get a 0x800700aa Bluetooth error. How can I solve this error?
The following ways are the most effective to fix the 0x800700aa Bluetooth error in Windows 7.
Method 1
a. Right-click on the start button.
b. Open Device Manager.
c. Expand Bluetooth Radios.
d. Right-click on the driver.
e. Update driver.
f. Search automatically for updates (you need an internet connection).
g. Complete the procedure.
h. Try to connect the Bluetooth headset now.
Method 2
e. Go to properties.
f. Go to the Advanced tab.
g. Remove the hyphen from the name of the device.
h. Save the changes.
i. You will be able to connect your headset now.
Notifications
