How To Solve 0x800bfa07 Windows Insider Error?
I am unable to solve the Windows Insider Error 0x800bfa07. Below is the screenshot of the error. Please suggest ways to fix the error.
The following methods can help you to solve the Windows Insider Error 0x800bfa07.
Method 1
a. Go to Settings and disconnect your insider account.
b. Open Fiddler.
c. Link your insider account in Fiddler.
d. Click on the Fix button.
e. Your error should be gone.
Method 2
a. Press Windows + R.
b. Type Regedit and press enter.
c. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsSelfhost.
d. Right-click on it.
e. Click on export (taking a backup).
f. Store it in a safe place.
g. Now, delete WindowsSelfhost.
h. See if you solved your problem. If no, then click on File and import the backup folder.
