How To Solve “cannot Load Resource Dll Replres.rll “ (Simple Way)
When a USB being plugged in, after a particular software is installed on my DELL laptop, error shows “cannot load resource dll replres.rll”. Please tell me what to do?
This kind of registry errors basically comes because of the effect of a new program is installed over old ones but the old was not successfully uninstalled. For the solution, you can use the RegCurePro.
Steps:
I Hope it will solve “cannot load resource dll replres.rll” error.
If the error appears after installing an application, you should probably check again the system specifications of the program you installed if you haven’t done it yet. One possible reason why a DLL file can’t be loaded is system incompatibility. The system specifications of the program will also show you if you forgot to install a required component like Microsoft .NET Framework.
A missing component can make a program work incorrectly like unable to call required function calls during startup. You may also try updating your operating system to the latest Service Pack to raise its compatibility level. If you have Microsoft Windows XP, download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP after Microsoft discontinued its support.
If you have Microsoft Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista. If you have Microsoft Windows 7, download Windows 7 Service Pack 1. This is the latest and only Service Pack update for Microsoft Windows 7. Microsoft has no plan of releasing future updates for this operating system.
If you have Microsoft Windows 8, you should update to the latest Service Pack for continued support, Microsoft Windows 8.1.
