How To Solve Error 10061 Connection Refused?
I was trying to connect to my email, where I got error 10061 connection refused. It sounds like it’s not my fault and the fault of the mail server. Still, is there any way I can solve this error?
Yes, you are right. You get error 10061 connection refused when the server refuses connection due to the wrong socket address. It may happen that the error is on your side.
1 – Check the stability of your internet connection, and refresh the page.
2 – Your firewall or antivirus may be blocking the socket. Just disable it once, and try connecting again. error 10061 connection refused.
3 – If you are getting this error repeatedly, scan your PC for virus and also perform a PC Tune-up.
These ways will surely help you out.
