How To Solve Error 1935 Assembly Component Windows 7 Manually?
I want to ask about error 1935 assembly component windows 7. I was trying to install the Creative Suite 4 when this popped up on my screen:
Method 1: Restart your computer.
Restart the system and then, begin the Creative Suite product installation again.
Method 2: First, uninstall and then reinstall the .NET Framework.
HKEY_LOCAL_MACHINE > SOFTWARE >Microsoft>NET Framework Setup>Full
HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>.NETFramework
HKEY_LOCAL_MACHINE>SOFTWARE>Microsoft>NET Framework Setup>Product
I’ve seen this error several times when installing an application and most of the time the problem is related to compatibility. You may get this error if the program is not compatible with your computer. You may also get this if a required component is not installed yet. Before installing any application on your computer, make sure your computer meets the requirements.
It is very important to check the system requirements of the software before installing it because there are times the program includes prerequisite components that need to be installed first before installing the program. If the program you are installing has prerequisites like Microsoft .NET Framework, Microsoft Visual C++ Redistributable, and others, these components need to be installed first.
Once all required components have been installed, you may now install the main software. If the required component or program is not included in the package, you can always search it on Google and download it.
Notifications
