How To Solve Error 404 Server Not Found HTTP Status Code Error
I was trying to access a website, and after a lot of waiting I got this error 404 server not found. What should I do?
The following steps might fix this issue
That’s a 404 error which indicates the page or content you are trying to access is not available or cannot be found on the server or on that location referred to by the link. The URL or link that you enter on your browser’s address bar is the actual path to the content or page you want to access.
If there is a change in the path like the filename of the page has been changed or the page was moved to another location or the page was deleted, this will trigger a 404 not found error.
If you are the webmaster of the site, you can check the name of the HTML document that the link points to or track the path of the document and replace the dead link with the right link. This HTTP status code may appear in different way because it can be customized by individual websites.
You might see it as “404 Error”, “404 Not Fount”, “HTTP 404 Not Found”, or “404 Page Not Found” and more.
