How To Solve Microsoftnokialumia 638 Not Ringing Or Vibrating While Incoming Calls.
Goatham Chan 10 points N/APosted on - 06/15/2017
I bought microsoftnokialumia 638 about a week ago and my phone recently received an update. And since then whenever an incoming call comes in my phone is not vibrating and sometimes it even fails to give a ring.
Now it’s only one week since I bought this phone I haven’t got along with it much, but I am sure I tried everything including changing the ringtone to increasing volume and enabling ringtone and vibration in my phone settings but for no use. So can anyone help me solve this issue?
Now Many users are reporting the same problem since the update so here is one of the effective solutions for this issue that helped many.
Follow my steps:
Step 1: Open the settings
Step 2: Now Go to “Notifications+actions”
Step 3: Then go to phone
Step 4: Now uncheck the show notification banners there
Step 5: Then change the “Notification sound” into none
Step 6: Now again go to settings
Step 7: Then open ringtone+sounds
Step 8: Now change your ringtone to any, other than pure. After the update is installed, it sets pure as default.
Step: Close settings and go back
Hope this helps you.
The Nokia Lumia 638 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public and released on December 2014 measuring 129.5 x 66.7 x 9.2 millimeters and weighing 136 grams. It uses micro-SIM card and has IPS LCD capacitive touchscreen display with 16M colors at 480 x 854 pixels screen resolution.
Nokia Lumia 638
It supports multi-touch protected with Corning Gorilla Glass 3 featuring ClearBlack display. It ships with Microsoft Windows Phone 8.1 powered by Qualcomm Snapdragon 400 chipset, 1.2 GHz Quad-Core Cortex-A7 processor, and Adreno 305 GPU. It supports microSD expandable up to 256 GB. It runs on 1 GB RAM with 8 GB internal storage. The primary camera supports 5 megapixels with 1/4″ and autofocus featuring panorama and geo-tagging.
It supports video recording but it has no secondary camera. It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 4.0 with A2DP and LE/aptX after WP8 Denim update, GPS with A-GPS and GLONASS support, FM radio, and microUSB 2.0. It has built-in accelerometer sensor. The pre-installed web browser supports HTML5.
It runs on removable BL-5H Li-Ion 1830 mAh battery. Now, to enable or disable the vibration, press the volume button either up or down to activate the sound panel. Next, tap the “v” button on the upper right-most corner of the screen. On the next screen, adjust the sound level to your desired loudness.
To enable or disable vibration, under the “Media + Apps” slider, tap “VIBRATE” to shift between “ON” and “OFF”.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
