How To Solve Mswstr10 Dll Missing Error
Asked By 5 points N/A Posted on -
I am unable to launch certain programs and play some games. When I launch these, I get an error saying the program cannot be started because mswstr10 dll is missing. How do I remove this error from my computer?
Answered By 0 points N/A #322980
The error you are getting is a DLL file error. DLL files are shared files that are used by the operating system on your computer to run programs that you install on the computer. DLL files are necessary for the normal functioning of your operating system. The mswstr10.dll file is associated with the Microsoft Jet Sort Library. Any program that requires this will not run properly.
To remove this error, you need to find this file on the internet. Download the file and place it in the required folder. This should remove the error. DLL errors are very common and are caused by incomplete installations, corrupt, or missing system files.
