How To Solve Smite Exe Bad Image Error
Smite is a very popular game. I play smite a lot on my system. Recently, however, I have started getting smite exe bad image error whenever I try to play the game. Re-installing the game did not help. How to remove this error?
Answered By 0 points N/A #321269
Sometimes when your system is missing some files or some files are corrupted, your computer can behave in weird ways. This could be one of the reasons behind getting the error. The exact message of the error should look something like this “bad image error it states: [C:WINDOWS\SYSTEM32\MSVCP110.dll] is either not designed to run on Windows, or it contains an error”.
Trying to reinstall the game will only help when something is wrong with the game files. If reinstalling it is not removing the problem, then the problem is with the system files. There is a native utility available in Windows called System File Checker. Run this utility and repair your system files by reinstalling missing files accordingly. Doing so should remove this error.
