I bought a new DX7 in the United States. I thought It was working fine until I put it on charging. At first, I thought it was broken completely, but it wasn’t. It started throwing the spektrum dx7 backup error. I cannot seem to find any way to solve this error in the manual or on the internet. Can someone help me out?
How To Solve Spektrum Dx7 Backup Error
Believe it or not,several DX7 users, not only from the US but even from other parts of the world have reported this issue. Once you put your device for charging, it throws the backup error. While no official solution, which works for all has been found there are some things that you can try.
First, make sure that all the sticks are on neutral. Then set the mix rudder on 1. Set the elevator to 1. Set the flap mix on 0, followed by the aux2 on 1. Turn the aileron on 0. Finally, keep the button up inserted and hit the power on button. Follow this, and you will find that things have started working, just like magic.
