How To Solve System Restore Not Working In Windows 7?
Hi everyone,
I’m trying to restore my system but the system restores not working. Please provide me to solution so that I make the procedure successful.
Hi everyone,
If you are having problem in running system restore problem there are 2 solutions given below.
You can run your pc in safe mode by restarting your system and keep pressing f8.
Or you can simply type ‘msconfig’ in start menu. Dialog box will appear you just have to enable the safe boot.
Search system restore in the search tab of start menu. Now at this point the system will successfully run in restore form.
If it still not works, adjust your disk space which is allocated.
Step1. Type ‘create restore’ in search menu.
Step2. Click Configure and move to next dialog box.
Step3. Now adjust the slider for adjusting the usage.
Step4. Click on Apply and then OK
