JOSE Adams
10 points
Posted on - 07/03/2019
From few days Taskeng.exe black screen is popping on my screen and becoming normal after a few seconds. I’m unable to conclude it whether as a malware or software problem. There is no error after so many scans also. It merely able me to read it. It happens whenever I open the system or restart it.
Than Gen
How To Solve Taskeng.exe Black Screen Problem?
Taskeng.exe is a task manager that keeps track of the tasks that should run predominantly. It can be due to incomplete downloads or downloads with malware. Run the scanner once in safe mode for efficient use and remove the virus if any. There may be some installations opposing Taskeng.exe, or the files would have removed mistakenly from the system. You should clean the junk and clean boot the system to know the reason. You should run the full scan to know about the malware if there and see the booting to know either it is solved or not.
