How To Solve The Acer 5536 Screen Not Coming On?
I have an issue – Acer 5536 screen not coming on. I connected an external monitor with my laptop, but still, I could not see any image. The power led is glowing. What to do?
Acer 5536 screen not coming on can be a fatal issue. Try the following methods.
Method 1
a. Unplug the charger/ power cable from your laptop.
b. Remove the battery. You can watch a video on removing the battery of your particular model if you do not know the process.
c. Press the power button for 30 seconds.
d. Attach the battery.
e. Connect your charger. Switch it on.
f. Turn on your laptop.
Method 2
a. Remove the back cover of your laptop.
b. Take out your RAM.
c. Take an eraser and clean your RAM.
d. Attach it to your PC.
e. Try to turn it on.
If the above methods did not help, there is a high chance that your Motherboard is fried. Go to the service center.
