How To Solve The Error 0x8007018b?
Hello, people. I am getting the 0x8007018b error while trying to get a file from a restore point. Please help me to fix the 0x8007018b error. Thank you.
Hello. The error 0x8007018b occurs due to disk corruption or corruption of system files. So to fix this error, follow the below methods.
Method 1:
Disable OneDrive
• In the bottom right corner, you’ll find ^ this symbol. Click on it and select the cloud icon.
• Right-click on the icon and select Settings.
• In the next window, navigate to the account tab, first click on unlink this PC, and next click on Unlink this account.
• Next, perform the restore.
Method 2:
New Restore point
• Type system properties, In the windows search box, open it.
• In that click on create.
• Give a name if your choice to the new restore point and click on create.
