I was trying to install an antivirus program on my computer. But then, my computer became very slow. So I decided to uninstall the antivirus program. Now, my computer constantly gives an error code 0x2 on the screen. Please help.
How To Solve The Error Code 0x2 In Windows?
You can try to restore your system to a point before you installed the antivirus program. To do so, you can perform these steps.
1. Firstly, make sure you have created a restore point.
2. Search for ‘restore’ in the Start Menu
3. Now in ‘Properties,’ click on ‘System Restore.
4. Click ‘Next’ and wait for few minutes
5. Reboot your computer
You can also opt for Start Repair Wizard. Search for the wizard in the Start Menu.
