How To Solve The Errors With Task Scheduler Helper.dll?
When I’m trying to use the printer to print my files from word or in some reader, it is showing a popup TaskSchedulerHelper.dll is not found. It is also popping up every time I start my system. I’m not getting what to install to get rid of this problem. Why is this occurring in my Windows 10?
Answered By 0 points N/A #319348
It may be caused due to software changes or missing of the file from the system. It can also be due to improper shutdown or any malware in the system. Remembering the functionality when the error occurred is very crucial in the solution of this error. You can scan through the System file checker for any corrupted file and restore them with the proper one. Running deployment image servicing and management checks the incorrect data and replaces it by the correct version. If there is any malware in that file then removing it and reinstalling can only solve the issue.
