I connected my computer to a network, but I am unable to access shared files. I am getting error 0x800704cf. The settings are fine as other computers can access the files. How to solve this problem?
How To Solve The File-sharing Problem On A Network In Windows 10 (error 0x800704cf)?
You should try to reset TCP/ IP and check the adapter settings to solve the 0x800704cf error. Here are the methods to do the same.
Method 1-
a. Right-click on the start menu, open settings.
b. Go to Network & Internet.
c. Click on Change adapter options.
d. Right-click on the connected network adapter.
e. Go to properties.
f. Uncheck the Client for Microsoft Networks option
g. Click on OK.
h. Restart your PC; you will not face the error.
Method 2
a. Open Command Prompt as admin.
b. Type ipconfig /flushdns, and press enter.
c. Type nbtstat –RR, and press enter.
d. Type netsh int ip reset, and press enter.
e. Type netsh winsock reset and press enter.
f. Restart your device.
g. You will solve your problem.
