How To Solve The Sqllib80 Dll Error
We have recently adopted the Oracle Developer 2000 Server. Everything was fine, and the installation was completed successfully. However, when we started using the client, it started throwing sqllib80 dll error. This has stopped our workflow and we are looking for a quick fix.
Answered By 0 points N/A #321291
The sqllib80 dll is a DLL file associated with the Oracle Developer 2000 Server series. Dll files exist outside the software since these are shared files. DLL errors are thrown when the said files are missing. In your case, the sqllib80 dll file is missing from your computers.
The solution to this problem is quite simple. A simple download can fix this problem. What you need to do is to find the file on the internet and download it and place it in the correct destination. DLL-Files.com is one website which allows you access to a large library of dll files. It also has a desktop client that you can install. You will find the missing dll file here. Download the file and place it in the systems folder to remove the error and start working normally.
