Hello everybody,
I am facing an error in Windows Updates since last three days, but I am unable to find a solution for the same. The error says windows update error code 800f0922. It leads to a failure in the installation of an upgrade. I am using Windows 8 on my computer.
Please help me in solving this issue.
Thank you in advance.
How To Solve The Windows Update Error Code 800f0922 Error.
First, check that all the services are running.
Then, follow these steps for Windows 8 operating system;
- Click on Start. Then, swipe in from the right, click Search, and type ‘Control Panel.’
- In the Control Panel search box, type ‘services.’
- Then, Click and open ‘View local services.’
- Finally, Start the service “Background Intelligent Transfer Service.”
If you are installing KB3022345 via Windows Update and you receive “error 800F0922”, here’s what you should do. The problem involves two Windows Updates: KB3045999 and KB3022345. The solution is quite simple but tricky. You need to install KB3022345 before installing KB3045999. Click “Start”, “Control Panel”, “Programs”, and then “View Installed Updates”.
This may take some time depending on the number of Windows Updates you have installed on your system. When the list is loaded, look for “KB3045999” then uninstall it. When you are prompted to restart your computer, do not restart your machine. After this, run Windows Update and install the KB3022345 update only, nothing else. Once this is installed, restart your computer.
After booting, run Windows Update again and install the KB3045999 update and then restart the machine again. This should fix the problem.
