How To Solve This 3ds The Remote Device Won’t Accept The Connection Problem?
Hi, I was facing this 3ds the remote device won’t accept the connection issue inside my PC. Please help me?
A) To solve this 3ds the remote device won’t accept the connection issue, you have to follow these steps:-
1. Open the Internet Explorer browser, and then, in the top right corner of your IE, click on settings that look like a gear > Internet options.
2. Now, tap on the Connections tab and tap on LAN settings.
3. Inside the Proxy server section, untick Use a proxy server for your LAN.
4. Inside the Automatic configuration section, the tick automatically detects settings. Then click on the OK button.
B) To solve this 3ds the remote device won’t accept the connection issue. You have to disable antivirus software temporarily as antivirus software sometimes blocks connections. Disabling it mighty solve your issues.
