How To Solve Windowsupdate_80246007
I get windowsupdate_80246007 when I tried to update my windows 7 32 bit PC. Can anyone help me solve this error?
You can try the following solution out and check if it works for you or not:
• Disable your anti-virus for a while and try to install it.
• You can download a repair tool from Microsoft and use it.
• Make sure that the public access for windows updates in windows firewall allowed.
• Install any of the registry cleaning tools that you find decent to clear all the errors caused by the registry.
• Clean boot your PC and try installing the update.
• You can manually install the update through the Microsoft site. If nothing else works out for you.
