I have been playing World of Warcraft game for 2 years now. Recently I formatted my computer, so the game uninstalled automatically. Now I logged into the game once, but today when I started my game, It is showing a dialog box saying fatal error 132.Now I don’t know what is the reason behind this so can anyone help me with the world of warcraft error 132 issue?
This error is mainly caused because your computer cant process which means read and write the temp files which is required to run your game. Now try the below steps to solve this issue :
Method 1: Delete the temporary files
Locate Interface folder and rename it as interface back up. Also, locate Cache and WTF folders, rename them too.
Method 2: Try updating your video drivers
Try updating your computers video drivers for which click on ATI or NVidia and update your drivers to the latest.
Method 3: Reinstall your game
Now one of the easiest fixes for any kind of errors related to any kind of games or application is to uninstall and then reinstall the game or that particular application. This allows the game or app to have afresh installation.
Method 4: Try cleaning the registry
Now, this is the last resort and try this method at your own risk. The registry is the part of your computer which should be handled with utter care, and if anything goes wrong, it may affect your entire system. Try using a good registry cleaner for this method.
If you want to play the game “World of Warcraft,” I don’t think you are installing it on the right platform. Installation will not happen if you try to install the game on the wrong operating system. Before installing “World of Warcraft,” make sure your computer meets the requirements. The game “World of Warcraft” supports Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit.
World of Warcraft
It will not install on Windows Vista and older operating systems no matter how you try, it will only trigger errors.
“World of Warcraft” requires Intel Core 2 Duo or equivalent AMD Phenom II X3 720 or faster processor, NVIDIA GeForce GT 440 or AMD Radeon HD 5670 or Intel HD Graphics 5000 or better video card, 2 GB RAM, 45 GB free space, 1024 x 768 minimum screen resolution, and broadband internet connection. To know if your video card is supported, head down to Windows Supported Video Cards.
The page also lists the video card brands and models that are not supported.
1....
