I recently bought the MD80 camera just because I wanted to try it out and what it feels like to be a spy. Once I purchased it, I tried to connect it to my laptop to view the footage it had captured, but I could not as I kept getting a driver error. On research, I found that I was missing the spca1528_v2220_m setup exe download. Where can I get this?
How To Spca1528_v2220_m Setup Exe Download
The camera you bought is advertised as a spy camera. First of all, be advised that invading someone’s privacy using such device can leave serious consequences for you. You got it right. It is a driver issue and can be solved once you get the said exe file.
Now, to download the said file, much like any other software, you will find numerous links to download it on a simple Google search. However, you cannot say whether or not these links are safe. It is advised that you only download software on the internet from websites that you trust. One of the sites is sematic.gs. Once again, I must say that please download the file only if you trust the website and make sure that you have proper anti-virus protection for your computer.
When you buy the MD80 camera, the driver should be included in the installation CD included in the package. Just insert the CD in your optical drive and install the driver. If you no longer have the CD or in case, there is no installation CD included in your product, just download the driver. Unfortunately, there is no manufacturer’s website available so you have to download it from elsewhere.
Try downloading this driver for the MD80 camera: D001 – MD80 Mini Camera Drivers. The driver is mainly used for its webcam mode. Once the drivers are installed, plug the camera on the USB port then turn the power on. Press the “M” button on the camera to enter webcam mode. The “Installing Driver Software” window will appear.
Once the installation is complete, you can view the live capture by running the “amcap.exe” program located in “Programs/SPCA1528/amcap.exe”. For more information about the camera, head down to D001 – MD80 Mini Camera (720×480) on 2KOOL4U.com.
