How To To Verify Update On Xiaomi Phone
I am unable to Verify Update on Xiaomi Phone after the regular update notification popped up and I began downloading the update. How do I fix this problem?
For the procedure, your device has to be more than 50% charged. Also, it requires sufficient storage space available for the update to be downloaded and a fast internet connection
Go to System Updates in your phone > Click on System Updates > Download the Update> Wait till it gets finished. After the update has downloaded, click on “Reboot now” and enjoy the update. The amount of issue arriving on your device is considerably decreased when you are keeping your device updated.
Notifications
