How To Troubleshoot 0x80070079 Error In Windows 10?
I am unable to complete backup in Windows 10 PC. I am encountering a 0x80070079 error. I need assistance in troubleshooting this error.
You can try to update your driver, and windows troubleshooter to troubleshoot the 0x80070079 error in Windows 10.
Method 1
a. Connect your PC to the Internet
b. Right-click on the start menu.
c. Open Device Manager.
d. Locate Network adapters.
e. Right-click on the adapter, and click on update driver.
i. Search automatically for updated driver software.
j. Try to backup after the process is complete.
Method 2
a. Open Control Panel.
b. Search Troubleshooting in the control panel’s search box and open it.
c. Click on View all.
d. Run the troubleshooter for Network adapters and Internet options.
e. You may not encounter the error again.
