How To Troubleshoot 0x8007045d Error?
I was copying files from an external drive to my PC, and suddenly an error pops up. The error code is 0x8007045d. I am unable to complete the file transfer. How to fix this issue?
Answered By 0 points N/A #342096
Before proceeding to any technical solution for fixing the 0x8007045d error, try these –
Method 1
Use different USB ports available on your PC. A defective USB port can cause this error.
Method 2
Insert the external drive on some other device, and check whether the problem occurs. Your external drive may be corrupted. In the next method, we will try to fix the external drive. If the problem persists, you may need to go to a technician.
Method 3
a. Sign-in as an Administrator on your PC.
b. GO to This PC.
c. Right-click on your external drive.
d. Go to Properties.
e. Go to the Tools tab.
f. You file an Error-checking section.
g. Click on Check.
h. Click on Scan Drive.
i. Repair drive.
j. This method will fix your drive.
