How To Troubleshoot 2123, There Was An Error In The Application Issue In Rosetta Stone?
I get 2123, there was an error in the application in the Rosetta Stone on my Windows PC. I am unable to use it. How to troubleshoot this issue?
There are a few methods that can help you troubleshoot 2123, there was an error in the application issue.
Method 1
a. Open the folder where the app is installed.
b. Right-click on the main installer file that was used to install the app.
c. Open Properties -> Compatibility.
d. Click on – Run the Compatibility troubleshooter.
e. Follow the instructions, and complete the process.
f. Click on Apply -> OK.
g. Launch the App.
Method 2
a. Press Windows + R on your keyboard.
b. Type %Programdata% and press enter.
c. Open the folder, Rosetta.
d. Rename Tracking.db3 to tracking.db3.bak.
e. Restart your device.
f. Launch the app.
Method 3
a. Disconnect the internet.
b. Turn your WiFi off, or disconnect the ethernet.
c. Restart your device.
d. Launch the app.
e. Then, connect the internet to your PC.
f. You will be able to use the app
Notifications
