How To Troubleshoot Error 0xc000007b
When I was trying to open an application I received an error called unable to start correctly error it is a 0xc000007b error, what does this error mean and how to troubleshoot this error?
This error usually means that you have a 32-bit OS, but you are trying to run a 64-bit version of the application. This will cause an error if you have a 32-bit OS then you are supposed to run a 32-bit version of the app only.
For troubleshooting, this error you need to restart your computer do it several times, and even if the program doesn’t start then move to the next step that is to uninstall and reinstall the program. If your program has infected with virus or worm, this will help as uninstalling that program and again reinstalling it will get rid of the virus, and maybe your application might start.
You need to reboot your system and restart your computer and this error will be resolved.
