How To Troubleshoot The 0xe06d7363 Printer Error In Windows 10?
I have an HP printer that is connected with my Windows 10 HP laptop. When I try to print color photos, I encounter a 0xe06d7363 printer error. I will be very grateful if anyone can suggest a fix. Updating the drivers did not help.
Answered By 20 points N/A #344212
I got a fix for the 0xe06d7363 printer error for the HP printers.
a. Remove the USB that connects your printer and PC, if any.
b. Go to the Control Panel
c. GO to Program & Features.
d. Click on your HP printer.
e. Uninstall it.
f. Go to the Control panel.
g. Open Devices and printers.
h. Right-click on any printer device in the list, and delete it.
i. Press Windows + R on your keyboard.
j. Type printui.exe /s and press enter.
k. There is a print server properties head.
l. Go to Drivers.
m. Remove everything from there.
n. Click Ok.
o. Press Windows + R on your keyboard.
p. Type c:/programdata and press enter.
q. Open the Hewlett Packard folder.
r. Delete the contents of the folder.
s. Restart your device.
t. Update your drivers from the HP website
u. Connect the printer.
