How To Turn On System Restore In Windows 10?
I encountered a problem with my Windows 10, and I was trying to go to a previous point where my windows worked properly after taking suggestions from google but found out there is no system restore point in my laptop. How to turn on system restore?
Answered By 10 points N/A #331692
Follow these steps to learn how to turn on system restore –
1 – Search “system restore” in the start menu and open “create a restore point.”
2 – The following window appears.
3 – Select the drive where you see “System.”
4 – Click Configure.
5 – Turn on system protection.
6 – You can adjust the maximum disk space that you want to allocate for this purpose, but Windows takes care of it, so sit back and click Apply -> OK.
