How To Type Infinity Symbol In Ms-word?
Hello experts,
Can anyone help for how can I type infinity symbol in Ms-word? Please provide me the steps to insert it.
Thanks in advance for the help.
Hello experts,
To insert a symbol in ms-word, you need to follow the steps:-
Place the cursor where you want to put in the symbol.
Click on Insert tab and click on the symbol at top right.
Drop down it if you find the symbol then its good otherwise click on more symbols.
Recognize the symbol you want to insert and hit on Insert.
You can use the shortcut key Alt+X to type infinity.
The infinity symbol is included among the symbols in Microsoft Office Word. You can even insert it into your Office Word document by just using the keyboard. To insert it using the keyboard, move the cursor to where you want the infinity symbol to appear. Next, press ALT + 236 (use the numbers on the num-lock keypad). The infinity symbol “∞” should then appear.
If you prefer inserting the symbol using the symbol button in Microsoft Office Word, in Office Word, select “Insert” tab. On the upper right corner of the screen, click “Symbol” to display the list then just select the infinity symbol among the symbols. If you don’t see it there, click “More Symbols.” Scroll down and look for the infinity symbol.
Once you located it, click it to select then click “Insert” and then close the dialog.
Notifications
