I have started using Outlook 2007 for a while now. I installed add-ins in Outlook 2007 as I thought it would be useful. But after I installed add-ins in Outlook 2007, my PC takes a longer time to shut down. Some of the applications are not running. Is there any way to uninstall add-ins from Outlook 2007?
How to uninstall add-ins in Outlook 2007?
It is simple. Open Outlook 2007 by typing ‘Outlook’ in the Search Bar of Start Menu. Now, click on the ‘Outlook’ icon. On the top left corner, click on the ‘File Menu’, after Outlook 2007 is opened. Now, click on the ‘Trust Center.’ A new dialog box will open. Click on ‘Add-ins.’ ‘Add-ins’ is situated on the left side of the dialog box. In the Manage drop-down menu, select ‘COM Add-ins’ and clock on ‘Go.’ The ‘COM Add-ins’ dialog box will appear. Remove the ‘Check Mark’ from all the add-ins which you want to be uninstalled and click on ‘OK.’ The desired ‘Add-ins’ will now be uninstalled from Outlook 2007.
The following image shows how the ‘COM Add-ins’ dialog box appears.
