amber ward
10 points
Posted on - 07/09/2017
Hello, experts, I want to uninstall my internet explorer. Please provide me the procedures to uninstall internet explorer 11 64 bit and that using control panel. Thanks in advance for the help.
eharper
10 points
How To Uninstall Internet Explorer 11 64 Bit Using Add/Remove Programs?
Click on the start menu.
Open the control panel.
Choose program manager and hit on the Uninstall a program link. You will get the list of the installed programs on your screen.
At the right side of the window choose View Installed Updates link
Search for internet explorer 11.
And click on it, at the top tab you will find an option to uninstall the program, click it.
Confirm your decision by clicking yes.
I don’t think you can uninstall Microsoft Internet Explorer. The Microsoft Internet Explorer is the built-in web browser of the Microsoft Windows operating system and there is no option to literally uninstall it from the system. If your existing version of the browser is just an upgrade, you can only remove the upgrade of the browser from the computer but not uninstall the browser itself.
If you don’t want to use Microsoft Internet Explorer as browser, the only way to get rid of it is to deactivate it from the components of the operating system. If you are using Windows XP, click “Start,” “Control Panel,” “Add or Remove Programs,” and then click “Add/Remove Windows Components” on the left pane.
In the “Windows Components Wizard,” uncheck “Internet Explorer” then click “Next” and then follow the instructions. This will remove Microsoft Internet Explorer from your system.
