I have used Kaspersky antivirus and installed Kaspersky Internet Security 2013. I want to move on and try some other options. I do not know how to uninstall this program from my computer after ending the subscription. Can you tell me how to uninstall Kaspersky internet security 2013?
How To Uninstall Kaspersky Internet Security 2013
Uninstalling as antivirus or security software is not something you think about every day, but when you have to do it for some reason or another, most people are left completely blank. Thankfully, most modern antivirus and security clients make it easy to uninstall them from the machine.
To uninstall Kaspersky Internet Security 2013, first, exit from the application. Now open the setup wizard and select Kaspersky Internet Security 2013 and click on uninstall or change. Follow the instructions on the uninstall client. If you are using Windows 10, find the Kasperksy icon in your start menu, right-click and click on uninstall and follow the instructions.
