How To Use Microsoft Management Console
I wanted to customize my windows operating system, but I don’t know how to use Microsoft management console. I want to know the usage of Microsoft management console.
Microsoft management console helps you to customize your administrative controls and customize your user interfaces too much easier extent. This is how to use Microsoft management console-
1.) Go to start > run > type MMC > click ok. A beginner console pop – up window opens.
2.) Click console > console menu > click add. This helps you enable and configure different snap-ins and customize them. Click add if you want to add different snap-ins.
3.) Select computer wizard snap-in from the list of snap-ins. Click local computer and customize all the settings if you want.
4.) Click close after completing. You will return to the console menu. Close the wizard now.
